Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Winter 2008 Graphics Performance Update Crysis - DirectX 10 Winter 2008 Graphics Performance Update Crysis - DirectX 10
Crysis
1,280 x 1,024 0xAA 8xAF, DirectX 10, High Quality
  • ATI Radeon HD 4870 X2 2GB
  • Nvidia GeForce GTX 280 1GB
  • Sapphire ATI Radeon HD 4850 X2 2GB
  • Nvidia GeForce GTX 260+ 896MB
  • ATI Radeon HD 4870 1GB
  • ATI Radeon HD 4870 512MB
  • Nvidia GeForce 9800 GTX+ 512MB
  • ATI Radeon HD 4850 512MB
    • 60.7
    • 38.0
    • 53.7
    • 31.0
    • 53.1
    • 32.0
    • 48.1
    • 28.0
    • 40.9
    • 24.0
    • 40.6
    • 23.0
    • 39.7
    • 24.0
    • 32.7
    • 18.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 2xAA 8xAF, DirectX 10, High Quality
    • 59.0
    • 38.0
    • 49.9
    • 30.0
    • 49.9
    • 29.0
    • 44.0
    • 26.0
    • 38.0
    • 21.0
    • 36.8
    • 20.0
    • 34.1
    • 0.0
    • 29.5
    • 15.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 8xAF, DirectX 10, High Quality
    • 55.2
    • 34.0
    • 47.1
    • 28.0
    • 45.9
    • 26.0
    • 41.3
    • 25.0
    • 32.5
    • 19.0
    • 32.2
    • 19.0
    • 30.8
    • 18.0
    • 25.2
    • 13.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 8xAF, DirectX 10, High Quality
    • 53.6
    • 26.0
    • 44.6
    • 28.0
    • 43.3
    • 28.0
    • 38.3
    • 24.0
    • 33.0
    • 20.0
    • 32.8
    • 19.0
    • 31.2
    • 20.0
    • 26.2
    • 15.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 8xAF, DirectX 10, High Quality
    • 46.5
    • 29.0
    • 37.6
    • 24.0
    • 37.3
    • 20.0
    • 32.5
    • 21.0
    • 26.4
    • 13.0
    • 25.4
    • 14.0
    • 23.4
    • 15.0
    • 20.6
    • 11.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 8xAF, DirectX 10, High Quality
    • 49.3
    • 31.0
    • 39.9
    • 25.0
    • 35.3
    • 22.0
    • 31.1
    • 19.0
    • 29.5
    • 18.0
    • 28.6
    • 16.0
    • 25.0
    • 16.0
    • 22.6
    • 13.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 8xAF, DirectX 10, High Quality
    • 45.4
    • 29.0
    • 36.7
    • 23.0
    • 32.4
    • 21.0
    • 28.1
    • 18.0
    • 27.5
    • 15.0
    • 26.4
    • 15.0
    • 20.7
    • 11.0
    • 20.5
    • 11.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 0xAA 8xAF, DirectX 10, High Quality
    • 31.1
    • 18.0
    • 24.7
    • 13.0
    • 21.7
    • 12.0
    • 19.0
    • 9.0
    • 17.4
    • 9.0
    • 17.1
    • 9.0
    • 14.2
    • 6.0
    • 13.5
    • 7.0
10
15
20
25
30
35
Frames Per Second
  • Average
  • Minimum
The GeForce GTX 280 again has an advantage over the Radeon HD 4850 X2 at lower resolutions, but as soon as you get to 1,920 x 1,200 it outperforms Nvidia’s flagship graphics card. AMD’s flagship card, on the other hand, has a clear lead in this title with high in-game settings and even manages to achieve a playable frame rate at 2,560 x 1,600 0xAA 8xAF.
Moving further down, the GTX 260+ is faster than the Radeon HD 4870 1GB by a considerable margin at some resolutions but at 1,920 x 1,200 in particular the two are on even footing. The same is true with the battle between the Radeon HD 4850 and GeForce 9800 GTX+ as well – the latter is faster at the resolutions that matter, but once the frame rate dips below the playability threshold the two are fairly evenly matched.
